In this Article
Did you know that Samsung SmartThings supports all IKEA Matter-over-Thread devices, including smart bulbs, plugs, remotes, and sensors that connect directly to…
1. Can Users Add Affordable IKEA Matter Products to an Existing SmartThings System?
2. Do IKEA Matter Devices Require a DIRIGERA Hub with SmartThings?
3. Do IKEA Matter Products Work in a Mixed-Brand Smart Home?
4. Do Door Sensors Work With SmartThings Family Care?
5. Can IKEA Air-Quality Sensors Support the SmartThings Sleep Environment Report?
6. Do IKEA Sensors Trigger SmartThings Routines?
7. Which IKEA Matter Devices Are Supported by SmartThings?
8. Does the IKEA BILRESA Scroll Wheel Remote Work With SmartThings?
9. What Are Matter and Thread?
10. How Does IKEA Expand an Existing SmartThings Setup?
Share this Blog Post
SmartThings and IKEA with a New Lineup of Matter-over-Thread Devices
Did you know that Samsung SmartThings supports all IKEA Matter-over-Thread devices, including smart bulbs, plugs, remotes, and sensors that connect directly to a compatible SmartThings? Integrating these devices into an existing SmartThings ecosystem gives users a simple, cost-effective way to grow their smart home for family care, sleep optimization, environmental monitoring, leak detection and alerts, smart lighting control, and other practical automation solutions.
Yes. IKEA’s Matter-compatible products lets SmartThings users add affordable, compatible smart lights, smart plugs, sensors, and controls to enhance their current SmartThings setup as needed, rather than replacing compatible, previously purchased products.
No. New IKEA Matter-over-Thread devices connect directly to a compatible SmartThings hub.. That means one less piece of hardware to buy, set up, and manage.
Yes. Supported IKEA Matter products integrate with compatible Samsung devices and other supported products using the SmartThings app. For example, users can connect an IKEA light, plug, control, or sensor and incorporate it into a SmartThings routine using a compatible Samsung appliance or device.
Most homes run more than one brand. SmartThings lets users mix and match compatible products by category, lighting, sensors, appliances, plugs, and controls, and manage all of it from one app, instead of buying every device from a single brand.
Yes. A supported IKEA door sensor serves as an input, providing activity data alongside SmartThings Family Care. For example, a caregiver might place a sensor on a door a parent uses often, then use the resulting open-and-close activity, alongside Family Care, to get a sense of whether that parent’s day is off to a normal start.
Yes. Compatible IKEA air-quality sensors provide data on bedroom conditions, i.e., temperature, humidity, and lighting levels, that SmartThings uses to generate the Sleep Environment Report. IKEA air-quality and temperature-and-humidity sensors measure parameters including temperature, humidity, CO₂ levels, and light intensity. SmartThings compares these readings against recommended sleep conditions and offers suggestions based on what it finds.
Yes. Supported IKEA sensors provide conditions that trigger SmartThings routines involving doors, motion, moisture, temperature, humidity, and other environmental changes. For example, an IKEA humidity sensor detects rising humidity and activates dehumidifier mode on a compatible connected air-conditioning unit. A  water-leak sensor detects moisture and notifies the user of a possible water leak. Additionally, door and motion sensors generate activity signals for compatible monitoring and automation routines. The sensor spots the event; SmartThings handles the alert, notification, or next action.
IKEA Matter-compatible devices span multiple smart home product categories. Below is a breakdown of some examples:
IKEA Product CategoryExampleHow to Use It With SmartThings
Smart bulbKAJPLATSLighting control and compatible routines
Smart LampVARMBLIXTLighting adjustment with color and temperature
Smart plugGRILLPLATS/TOFSMYGGAConnected-device control and compatible routines
Smart remote controlBILRESASupported lighting control
Temperature/humidity sensorTIMMERFLOTTEEnvironmental monitoring and humidity-based routines
Air-quality sensorALPSTUGAEnvironmental monitoring
Open/closed sensor (door)MYGGBETTDoor activity and compatible monitoring routines
Moisture/water-leak sensorKLIPPBOKMoisture detection and alerts
Motion sensorMYGGSPRAYMotion detection and compatible routines
This range covers smart lighting, environmental monitoring, motion and activity detection, open/closed status, and connected-device control, so users can pick what fits their home.
Yes. The IKEA BILRESA scroll wheel remote control supports lighting products through SmartThings. Rotating the wheel enables precise adjustments to brightness and color temperature. SmartThings and IKEA conducted multiple rounds of connectivity validation before market release to test pairing and operation through the SmartThings app.
Currently, BILRESA supports lighting control and blind control (via Matter and Zigbee), with plans for expansion to more types of blinds and more device types in the future.
What SmartThings Hardware Do Users Need for IKEA Matter-over-Thread Products?
Supported IKEA Matter-over-Thread devices require access to a compatible SmartThings hub with Thread support.
Select Samsung TVs, refrigerators, and monitors can serve as that hub. SmartThings hub and Thread border router functionality depend on the individual Samsung model, not just the product type.
Users without one of these models can add a dedicated SmartThings hub, like the Aeotec Smart Home Hub 2.
Matter is an industry smart home connectivity standard developed by the Connectivity Standards Alliance to help compatible devices from different manufacturers work across supported ecosystems.
Thread is a low-power wireless networking technology used by many Matter-compatible smart home devices.
SmartThings supports Matter-over-Thread alongside other technologies such as Zigbee and Z-Wave, allowing compatible products using these technologies to operate through SmartThings.
SmartThings was also the first to adopt Thread version 1.4, built  to increase interoperability between Thread networks from different manufacturers.
SmartThings has supported Matter since the standard’s public launch and puts every certified device through rigorous, multi-round interoperability testing, reflecting its position as a quality leader in the Matter ecosystem.
With the addition of IKEA’s product lines to the list of options for customers of SmartThings that are compatible, SmartThings has given its customers additional options to select from when it comes to light control, sensor functionality, environmental monitoring, and automation. Today, users have more affordable Matter-based devices to meet their household needs, and SmartThings can help control them.
These product integrations support SmartThings’ strategy of growing its ecosystem through collaborations with other manufacturers, giving users more options to create a smart home system that meets their individual needs and preferences.
Ready to add IKEA to your setup? Do the SmartThings — open the app and start connecting.
Subscribe for more articles like this!
Your email address
[contact-form-7 id="831e457" title="Contact form"] You may opt-out at any time. Privacy Policy.
Learn more about becoming a SmartThings partner.
Work With Us
Inspire the world and create the future of IoT at SmartThings.
You Might Also Like...
SmartThings Updates
August 14, 2014
SmartThings, Samsung, and the Open Platform
Friends, Today is a big day for SmartThings. I’m excited to announce that SmartThings has been acquired by Samsung and will operate as an independent company within Samsung’s Open Innovation Center group. It has always been our goal to create a totally open smart home platform that brings together third-party developers, device makers, and consumers. We’re thrilled that Samsung fully supports this vision. We will continue to run SmartThings the way we always have: by embracing our community of customers, developers, and device makers and championing the creation of the leading open platform for the smart home. Our growing team will remain fully intact and will relocate to a new headquarters in Palo Alto, CA. In short: SmartThings will remain SmartThings. (more…)
Read More
SmartThings Updates
March 31, 2015
Update: SmartThings Hub & Hardware V2
Earlier this year we announced that we’ll soon unveil the next generation of the SmartThings Hub and several sensors. We wanted to provide a quick update on our progress to date. (more…)
Read More
SmartThings Updates
September 3, 2015
The Next Generation of SmartThings is Here
We’re excited to announce that the next generation of the Samsung SmartThings Hub, a new lineup of products, and a brand-new SmartThings app experience is available today. Our mission has always been to create the easiest way for people to turn their home into a smart home. In fact, we started SmartThings out of a desire to know the answer to a basic but deeply personal question: is everything OK in my home.  We believe our latest product evolution delivers on this ambition. Here's a look at what's new and improved: The New Samsung SmartThings Hub and Sensors The new Hub enables video streaming, has battery backup that lasts up to 10 hours, and can run certain functions locally to improve performance and continue to operate without an internet connection. The Hub will continue to support ZigBee, Z-Wave, and local internet connected devices. Two USB ports and embedded Bluetooth will support future expansion. The new collection of Samsung SmartThings sensors are now smaller and have been redesigned with a sleeker, more contemporary look to fit seamlessly into the background of your home. The New SmartThings App Experience The free SmartThings app has been redesigned for easier navigation and a more intuitive experience.  You can now directly organize and control your connected devices by room, view live streaming from cameras, quickly set up and run routines, explore the marketplace of nearly 200 devices now compatible with SmartThings, and so much more. One of the exciting new features of the SmartThings app experience is Smart Home Monitor– an integrated home monitoring solution. Smart Home Monitor allows you to receive alerts and take action when SmartThings detects unwanted entry or motion, smoke or fire, leaks, or other important activity. Existing customers will be able to configure Smart Home Monitor from their dashboard within 24 hours after downloading the updated app. With Smart Home Monitor, our Hub version 2, and a connected camera, you can also get instant alerts with an accompanying video-clip when these unexpected events occur.  Video buffering in the new hub means clips can start prior to the event so you can see exactly what is happening in your home. Video clips will eventually be a premium feature within Smart Home Monitor but are available in beta as a free trial through 2015. After the free trial, a premium version of Smart Home Monitor, which includes video clips, will be available for $4.99 per month. Live streaming will always be free. The new SmartThings app will be available for free download on iOS and Android starting today, with Apple Watch, and Gear S apps to follow. Be sure to check out our post for a more in-depth look at the app’s new features. We would like to extend our heart-felt thanks to our customers, supporters, and developer community. Your commitment, feedback, and ideas are what make our open platform truly special. We hope you you enjoy the new SmartThings experience.
Read More
Our Most Popular Categories
