It’s Earth Month, which means now is the best time to activate a sustainability routine with SmartThings Energy.
Did you know? According to the U.S. Department of Energy, the average American shells out $2,000 every year on energy bills. But guess what? Some of that money could be going down the drain because of how we use energy at home. With SmartThings Energy, you can save money while creating automated energy-saving routines. Enjoy peace of mind knowing you’re making your home and the planet better for you and your family.
Read on for tips on how to get the most out of SmartThings Energy, your smart appliances, and devices that work with SmartThings.
What is SmartThings Energy?
Ever wish you had a personal energy assistant? That’s SmartThings Energy. Available in the SmartThings app, SmartThings Energy helps you take control of your carbon footprint and cut your energy bills by letting you check your home energy use from anywhere.
Use the service to manage the energy usage of any of your devices that work with SmartThings, create energy-saving routines, get impactful energy-saving tips, and use AI Energy Mode to maximize your energy use.
Besides helping your devices run smarter, SmartThings Energy also supports you in larger energy-saving efforts. In times of high energy demand, energy suppliers may charge you higher rates, known as Demand Response. With SmartThings Energy, you can configure your #smart devices, such as your Nanoleaf lights, TP-Link plugs, and smart thermostat, to run less during these peak times. This not only cuts your energy bills but also helps the environment.
SmartThings Energy can also help you leave more money in your pocket. By simply monitoring and cutting down on your home energy use, you could score cash rewards and lower your utility bills with our energy savings programs! Stay tuned to learn more.
What is AI Energy Mode?
Artificial Intelligence (AI) Energy Mode is an innovative feature within SmartThings Energy, which can save you up to 70% of energy consumption on select products and cycles.
AI Energy Mode learns your routines and adjusts your devices to save energy without you lifting a finger. It uses machine learning to recognize when your energy use goes beyond the targets you’ve set in SmartThings Energy. Plus, it gives you insights into why it happened.
Let’s look at some of the ways AI Energy Mode helps with your everyday routines.
Washer & Dryer: From your workout clothes to the kids’ athletic gear, it can feel like you’re constantly doing laundry, which means you’re using a lot of water.
Thankfully, AI Energy Mode optimizes your Samsung Bespoke Washer & Dryer. The Bespoke AI Washer adjusts wash cycles based on load size, potentially reducing energy usage by up to 70%. Meanwhile, the Bespoke AI Dryer monitors temperature and humidity, with AI Dry potentially cutting energy usage by up to 20%.
Refrigerator: Your fridge is a major energy consumer in your home, running constantly even when you’re not there. But what can you do about it? Turn to AI Energy Mode. It ensures you’re using your Samsung Bespoke Refrigerator efficiently by optimizing compressor speed, defrost cycles, and temperature settings, potentially reducing energy usage by 15% during operation and an additional 15% when not in use.
Whether you’re out of town or simply away for a while, rest assured that you’re conserving energy while keeping your groceries at their ideal temperature.
Air Conditioning: Typically, 43% of a home utility bill goes to heating and cooling. Now, with many of us working from home, our AC usage tends to increase, especially as warmer temperatures approach.
With AI Energy Mode, your Works with SmartThings thermostat becomes smarter, adjusting settings based on your usage patterns, room temperature, and humidity. No need to compromise your comfort to save energy.
TV: Whether you’re watching a movie at night or the baseball game during a bright, sunny Sunday with your Samsung Frame TV, AI Energy Mode ensures you always have the perfect brightness for the best viewing experience. Activating AI Energy Mode triggers your TV’s processor and sensors to detect and analyze your room’s environment and adjust the relevant settings, potentially saving up to 20% energy. No more fiddling with brightness settings.
Plus, if you accidentally leave the TV on in another room, it automatically dims its brightness when it detects no viewers for more than two hours.
This is just scratching the surface of what SmartThings Energy can do for you. Any way you use it, SmartThings Energy takes care of the little details so you can focus on what truly matters—living your life to the fullest.
This Earth Month, #DoTheSmartThings and download the SmartThings app in the Google Play or Apple Store to activate SmartThings Energy and start living a more sustainable life.
