Try This: A Door That Can Warn You When Something Unexpected Happens
“I put a SmartThings Motion Sensor on my door that sends me a notification when there is unexpected motion in my home.”
Want to know that everything is OK at home? Keep track of any unexpected motion in the house with the SmartThings app and Motion Sensors, and get an instant alert if anything is detected.
  • Use the “Add Device” feature in the SmartThings app to pair a SmartThings Motion Sensor with your SmartThings Hub.
  • Place the SmartThings Motion Sensor in the living room where it can easily detect motion.
  • Use the “Smart Home Monitor-Security” SmartApp in the Marketplace section of the SmartThings app to configure your motion triggers.
  • Note: You probably want to configure this to happen only when your home is in “Away Mode” so you only get alerts when you’re away.
Need some more Motion Sensors? Grab some here.
See more Monitoring and Security smart setups!
