The Ultimate IFTTT Guide
It’s no secret that we’re big fans of IFTTT.
The SmartThings channel on IFTTT is packed with 180 valuable if-this-then-that recipes that let you seamlessly integrate your favorite products and online services with the everyday things around you.
To help you make the most of IFTTT, we wanted to point you toward MakeUseOf.com’s Ultimate IFTTT Guide. Give it a read, put the Internet to work for you, and start bridging the physical and digital worlds.
  • metz2000
    The MakeUseOf.com link is dead.
    Tried to connect to IFTTT and I’m supposed to select From what is a drop down list but is empty. No other option to connect.
  • Mike Turner
    Just bought SmartThings starter kit and tried authorizing iftt but as per metz2000 there is a drop down saying list saying ‘select from’ that is empty and no way to authorize :(
  • Matt
    The same. Bump!
  • Terris Linenbach
    I set up one sensor. Then I looked at my SmartThings hub SmartApps. There’s nothing listed in there for IFTTT. Wow! How does IFTTT get the data from my hub?
  • Nicholas Komma
    So can i set a routine from my alexa that arms my home in SMARTTHINGS with IFTTT?
    • EPoole
      You can create a simulated switch and then use Alexa or Google Home to trigger said simulated switch. Just need to assign the simulated switch in your Smartthings app to trigger event you want (Good Night smartapp).
